Revit API create wall
Here are 3 of the create wall with different overloads.
IList means the curves must form a closed loop?
Does this mean I can’t use the 5 input version for a single wall?
The 6 input version has XYZ normal… When would a wall not have this?
5 &6 are for wall by profile. So yes, you can create a single wall with it.
The profile needs to be in elevation of course.
What’s cool with those overloads is, if you provide a typical wall shape (square or rectangle), it doesn’t show as a profile wall after creation. It’s modifiable like a normal wall. (Or at least that’s how I recall it working)
Ahhhh!!! Thank you!
Can’t believe I missed the word, ‘profile’. :smile:
Also, I didn’t “recognise” you there… New picture :astonished: and new words. Congrats on the new job :slight_smile:
What about the XYZ?
Thank you! Finally changed form the south park profile picture. :sweat_smile:
I believe XYZ is facing orientation of the profile wall.
You mean for creating sloped walls?
I don’t think so. But I’m not too sure. I think it’s just for a flipped facing scenario
