Revit Analytical Model _ Releases / Memeber Forces
I’d like to control these properties of the analytical model in Revit but it doesn’t work well.
Does anyone have ideas to check release properties?
There are actuallly two parameters with the same name for each release. You need to use the BuiltInParameter name to set the correct one. (e.g. BuiltInParameter.STRUCTURAL_START_RELEASE_FX)
The python script:
# Code by Einar Raknes, 2018
# Import List ( ICollection(ElementId) = List[ElementId]() )
clr.AddReference('System')
# Import Revit API
clr.AddReference('RevitAPI')
# Input
element = UnwrapElement(IN[0])
value = IN[1]
 #Make changes to Revit DB in a Transaction
element.get_Parameter(BuiltInParameter.STRUCTURAL_START_RELEASE_FX).Set(value)
OUT = 0
