i’m trying to return all ucs names of a drawing by python, but can’t see what i’m doing wrong here.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
ucs_list = []
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
# Place your code below
ucs_table = t.GetObject(db.UcsTableId, OpenMode.ForRead)
for ucs_id in ucs_table:
ucs = t.GetObject(ucs_id, OpenMode.ForRead)
ucs_list.Append(ucs.Name)
# Commit before end transaction
t.Commit()
pass
OUT = ucs_list
got it working by making a custom node in c#, here is the code to learn and share.
I further wanted it to convert it to a coordinate system.
now it’s just a text input and coordinate output
public static CoordinateSystem UCSByName(string ucsName)
// Get the current document and its database
var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
try
// Get the UCS table from the database
UcsTable ucsTable = (UcsTable)tr.GetObject(db.UcsTableId, OpenMode.ForRead);
// Check if the UCS exists in the table
if (!ucsTable.Has(ucsName))
throw new ArgumentException($"UCS '{ucsName}' not found.");
// Get the UCS record
UcsTableRecord ucsRecord = (UcsTableRecord)tr.GetObject(ucsTable[ucsName], OpenMode.ForRead);
// Get the UCS origin and axes
Point3d origin = ucsRecord.Origin;
Vector3d xAxis = ucsRecord.XAxis;
Vector3d yAxis = ucsRecord.YAxis;
Vector3d zAxis = xAxis.CrossProduct(yAxis);
// Return as a Dynamo CoordinateSystem object
return CoordinateSystem.ByOriginVectors(pToDynamo(origin), vToDynamo(xAxis), vToDynamo(yAxis), vToDynamo(zAxis));
catch (Exception ex)
throw new InvalidOperationException($"Error retrieving UCS '{ucsName}': {ex.Message}", ex);
finally
tr.Commit();
// Extension methods to convert AutoCAD types to Dynamo types
private static Autodesk.DesignScript.Geometry.Point pToDynamo(Point3d point)
return Autodesk.DesignScript.Geometry.Point.ByCoordinates(point.X, point.Y, point.Z);
private static Autodesk.DesignScript.Geometry.Vector vToDynamo(Vector3d vector)
return Autodesk.DesignScript.Geometry.Vector.ByCoordinates(vector.X, vector.Y, vector.Z);
