Hello all,
I’m looking to search a category of ‘Rooms’, then based around the parameter of ‘Required Area’, filter out the values hitting ‘zero’ (0.000m²) and replace those values with a non-value, or null value. The ‘Required Area’ is a calculated value that is based off what is real in the model vs. what is required by the employer.
It has an added complexity of being a Calculated Value, which by default until we input ‘Employers Required Area’ is ‘null’, but as soon as you put anything in it populates with a number. If you remove said ‘Employers Required Area’, the value reverts to 0.000m² and not null.
Am I approaching it correctly? I’m a little stumped.
