Repeat data in list
Hi there, I have two lists, one has the amount of repeating and one the vales to be repeated. Say if the values to be repeated are 1, 2, 3, 4, 5 and the number of repetitions are 2, 4, 2, 3, 1 I would expect to get a list as follows: 11, 2222, 33, 444, 5 How would I do this? All my attempts so far haven’t worked, Dynamo keeps wanting to grab the whole list as a group and repeat that multiple times.
In the image above I’m looking for a nested list who’s value is 0 and count 6, value is 1 and count 4, value is 2 and count 5 etc. etc. Hope this makes sense.
Cheers,
Hi Mathew,
It might have something to do with your lacing. If I understand your example above correctly, the following should work for you:
Hi Mathew,
here’s another aproach in case you want it as lists
20160421-4
Thanks for sharing! This really helped me out of a rut
Will there a solution to repeat null data?
Hello…could Ofreateditem work for you ?
That’s interesting. List.Cycle and List.OfRepeatedItem have similar function.
Yes should have, but haven’t :wink:
