Rename input in Custom Node
How do I Rename the input For the node IN[0] and in[1] to Solid and Unobstructed ,And how do i make it accept Bool only.
In your first input, type Solid:bool=true
In the second, type Unobstructed:bool=false
That’s all.
Where Exactly??
Read this how to create custom node Creating a Custom Node | The Dynamo Primer
This uses Code Blocks and works…But can it be Done in Python ITself??
@ashwinash112
Do u mean this Part??
Yes But it uses Code Blocks…i Dont see any Python there…
I tried Doing it inside the Python Node But it wouldnt Work.
It doesn’t really matter if you have a python script node. Same process if you have one.
http://primer.dynamobim.org/en/10_Custom-Nodes/10-4_Python.html
