hello everybody,
I’ve several families in a project made by hundred of nested families (generic models), I can create all the assemblies I need easily but the software generates the list,into the project browser, with generic names as in the following picture:
do you know if is possible to rename assemblies according to the original type name of the family itself?
it is still not the solution, but maybe one user can trigger the solution…
Hi! Thank you so much for your response, I’ll checkt it out and hopefully i iwll get what i want!
After all this time i come back with a solution! I’m leaving the script here below. important is to have a schedule with “generic model” and “generic model:assembly name” available in the fields.
Cheers!
2. AZA_Rename Assembly.dyn (21.1 KB)
