Remove all the Assemblies without error warning window
I want to delete all assemblies of the project and also I do not want to have to hit the button Delete Element(s) of the warning error screen given by Revit immediately after an assembly is deleted.
I tried with python code like that but I still see the error window and it does not conclude until I select that option to Delete elements, it is like to confirm I acknowledge all of it will be removed.
clr.AddReference('RevitAPI')
# Retrieve assembly elements from the document
collector = FilteredElementCollector(doc)
assemblies = collector.OfCategory(BuiltInCategory.OST_Assemblies).WhereElementIsNotElementType().ToElements()
# Disassemble assemblies
for assinst in assemblies:
    assinst.Disassemble()
# Handle failures
options = TransactionManager.Instance.GetFailureHandlingOptions()
options.SetFailuresPreprocessor(DeleteElementsPreprocessor())
TransactionManager.Instance.SetFailureHandlingOptions(options)
class DeleteElementsPreprocessor(IFailuresPreprocessor):
    def PreprocessFailures(self, failuresAccessor):
        failureMessages = failuresAccessor.GetFailureMessages()
        for failureMessage in failureMessages:
            if failureMessage.GetFailureDefinitionId() == BuiltInFailures.GeneralFailures.DeletingElementsFailures:
                failuresAccessor.ResolveFailure(failureMessage)
        return FailureProcessingResult.Continue
OUT = "Assemblies disassembled successfully."
I resolved it myself, just delete all views of assemblies first so Revit does not warning about losing them, very silly…
# Delete assembly views
viewsToDelete = [view.Id for view in FilteredElementCollector(doc).OfClass(View).ToElements() if view.IsAssemblyView]
for viewId in viewsToDelete:
    doc.Delete(viewId)
assemblies = FilteredElementCollector(doc).OfClass(AssemblyInstance).ToElements()
for assembly in assemblies:
    assembly.Disassemble()
OUT = "Assembly views and assemblies disassembled successfully."
