ReferencePlane within Element
you can get the reference planes with the method FamilyInstance.GetReferenceByName and indicate which reference you want, in this case I took “Center (Left/Right)”.
Apparently the node you are using takes only model lines as reference, so it’s just easier to use doc.Create.NewDimension in Python, it’s basically working in the same way.
#Input
element = UnwrapElement(IN[0])
line = UnwrapElement(IN[1]).GeometryCurve
ref = ReferenceArray()
#Get Reference Planes from Families
for x in element:
	a = FamilyInstance.GetReferenceByName(x,"Center (Left/Right)")
	ref.Append(a)
#Create Dimension
dimension = doc.Create.NewDimension(doc.ActiveView,line,ref)
OUT = dimension
Let me know if it works
