So I wan’t to get a geometrical reference of a generic model. I’m able to get solids but how to get a reference to its faces? I’m inspired by this post of @MartinSpence Multiple Spot Coordinates
clr.AddReference('RevitAPI')
opts = Options()
opts.ComputeReferences = True
floorSolid = UnwrapElement(IN[0]).get_Geometry(opts)
df = []
for i in floorSolid:
df.append(i.GetInstanceGeometry())
OUT = df[0]
Like so:
#clr.AddReference('RevitNodes')
#import Revit
#clr.ImportExtensions(Revit.Elements)
#clr.ImportExtensions(Revit.GeometryConversion)
opts = Options()
gElem = UnwrapElement(IN[0]).get_Geometry(opts)
df = []
for gObj in gElem:
if isinstance(gObj,GeometryInstance):
for iObj in gObj.SymbolGeometry:
if isinstance(iObj, Solid):
for f in iObj.Faces:
df.append(f.Reference)
OUT = df
Thank you Sir! This is the part I’ve missed SymbolGeometry . Or rather didn’t knew about… How did you learned about this? Because I’ve called with dir() all attributes and that thing is not there…
Thanks! I’ve knew about the docs, but there’s less to non explanation about what goes where… And for a newbie with python it’s very problematic because there’s nobody to explain…
Well, sometimes it is a bit of a trial and error. For me it would also be more logical to use GetInstanceGeometry rather than SymbolGeometry - but it did not work…
There is not much info about Python in RevitAPI context…usually you have to translate C# solutions (from eg. The Building Coder or official API forums).
It gets bit easier with time
Thanks for this hint! Such a small detail makes such a great difference
