Quick Dimension Question
In the last example the line is made in dynamo from the grids start points.
Here is the code, but you can learn a lot from transcribing!
#Converting input from Dynamo to Revit
line = IN[0].ToRevitType()
grids = UnwrapElement(IN[1])
#Getting refrences from grid
gridRef = ReferenceArray()
opt = Options()
opt.ComputeReferences = True
opt.IncludeNonVisibleObjects = True
opt.View = doc.ActiveView
for grid in grids:
	for obj in grid.get_Geometry(opt):
		if isinstance(obj, Line):
			gline = obj
			gridRef.Append(gline.Reference)
#Create the dimension in a transaction
dim = doc.Create.NewDimension(doc.ActiveView, line, gridRef)
OUT = dim
