hello, I’m a limted user with python I am trying to set multiple values based on the length of the pipe but I don’t know why it gave the second list as length number, not y value ?
I believe this is the thing you’re looking for.
x_val = (IN[0])
y_val = (IN[1])
x = []
for i in x_val:
if i > 3000:
x.append(['Pipe is more than 3000', i])
y = []
for i in y_val:
if i < 3000:
y.append(['Pipe is less than 3000', i])
OUT = x, y
use also the frame (import the libraries)
Looks like you’ve an indented block, line 7.
Tab the line out like you’ve done in line 12.
… and there’s a Typo…
there needs to be tabs/spaces here…
It would be good to see the error message
Hope that helps,
Mark
updated the script
x_val = (IN[0])
y_val = (IN[1])
testx = 3000 #or assign input
testy = 3000 #or assign input
x = []
for i in x_val:
if i > testx:
x.append(['Pipe is more than: ' + str(testx), i])
elif i < testx:
x.append(['Pipe is less than: ' + str(testx), i])
pass
y = []
for i in y_val:
if i > testy:
y.append(['Pipe is more than: ' + str(testy), i])
elif i < testy:
y.append(['Pipe is less than: ' + str(testy), i])
pass
OUT = x, y
Here’s a version of the more basic one
xVal = IN[0]
yVal = IN[1]
xOut = []
yOut = []
for x in xVal:
if x > 3000:
xOut.append(['Pipe is more than 3000', x])
for y in yVal:
if y <= 3000:
yOut.append(['Pipe is less than or equal to 3000', y])
OUT = xOut, yOut
You have to correct the typo I made whilst copying in line 18 by removing the space at the beginning, I’m sorry.
thank you so much, I really appreciate your help
Please mark the answer as ‘solution’ if it solved your problem for other users to see.
