I can muddle my way through a Dynamo script when needed, but I’ve never attempted a Python Script node, so I turned to AI to write a Python script node to do the one piece of my graph that I couldn’t string together with OOTB nodes. As you may have surmised, the script keeps erroring and my lack of knowledge does not allow me to troubleshoot it properly, or as the saying goes “garbage in, garbage out”, what AI gave me was complete trash to begin with.
My intent with the dynamo graph is to grab all the COGO points in a drawing file and then read the Property Set Definition values for all those COGO points. I would then push those COGO points with a particular value for the particular Property Set Definition field and then put them into a Civil 3D point group. From what I could tell there are no OOTB nodes for COGO points that will read the Property Set Definitions assigned to them, so that led me to attempting to create a Python Script Node that would look for the Property Set Definitions of the COGO points I passed to it. From there I assumed with OOTB nodes I could group and filter as needed to whittle the list of points down to the points with a particular value in their Property Set Definition and then create a new point group. I am including the code I got from the AI google search. Is there anything there that can be troubleshooted to get it to work? Thank you for reading.
# Import standard Civil 3D/AutoCAD .NET assemblies
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
# Import AEC Property Data assemblies for Property Sets
import Autodesk.AutoCAD.DatabaseServices as acadDB
import Autodesk.Aec.PropertyData.DatabaseServices as aecPD
import Autodesk.AutoCAD.ApplicationServices as acadApp
# Inputs: Expects a list of Dynamo COGO Point objects
cogo_points = IN\[0\] if isinstance(IN\[0\], list) else \[IN\[0\]\]
output_data = [ ]
# Get the current drawing document and database
adoc = acadApp.Application.DocumentManager.MdiActiveDocument
# Safety check for empty inputs
if cogo_points and cogo_points\[0\] is not None:
with adoc.LockDocument():
with adoc.Database.TransactionManager.StartTransaction() as trans:
for cp in cogo_points:
point_info = {"CogoPoint": cp, "PropertySets": {}}
# Extract the native AutoCAD Object ID from the Dynamo wrapper
try:
obj_id = cp.InternalObjectId
except AttributeError:
# Fallback for older Dynamo versions
obj_id = cp.InternalElement.ObjectId
# Get the collection of Property Sets attached to this Object ID
p_set_ids = aecPD.PropertyDataServices.GetPropertySets(obj_id)
for p_set_id in p_set_ids:
# Open each Property Set object
p_set = trans.GetObject(p_set_id, acadDB.OpenMode.ForRead)
# Retrieve the Definition name of this Property Set
# via its corresponding PropertySetDefinition object
p_set_def = trans.GetObject(p_set.PropertySetDefinitionId, acadDB.OpenMode.ForRead)
p_set_name = p_set_def.Name
properties_dict = {}
# Iterate through all properties defined in this set
for prop in p_set.PropertyValues:
prop_id = prop.PropertyId
# Get the key/name of the property from the definition metadata
prop_def = p_set_def.Definitions[prop_id]
prop_name = prop_def.Name
# Fetch the actual assigned value
prop_value = prop.Value
properties_dict[prop_name] = prop_value
# Group data under the Property Set Definition Name
point_info["PropertySets"][p_set_name] = properties_dict
output_data.append(point_info)
trans.Commit()
# Output to Dynamo
OUT = output_data
