Hi, I’m trying to get handrails from railing to get then their length using Dynamo. Unfortunately, I’m stuck with getting Handrails, list of values just shows nulls every time for any kind of railings
I’ve already seen similiar script for Rail Types and it is work. And that’s my first Python script, so here can be some really stupid mistakes, sorry
That’s my script:
clr.AddReference(‘RevitAPI’)
railing = UnwrapElement(IN[0])
rrail = railing.GetHandRails()
lst =
lst.append(rrail)
lst.append(doc.GetElement(rrail.PrimaryHandrail())
lst.append(doc.GetElement(rrail.SecondaryHandrail())
lst.append(doc.GetElement(rrail.TopRail())
OUT = lst
Thank you in advance
hi @Artemisia111
replace your python script with this:
clr.AddReference("RevitAPI")
railType = doc.GetElement(railing.get_Parameter(BuiltInParameter.ELEM_TYPE_PARAM).AsElementId())
lst = list()
lst.append(railType)
lst.append(doc.GetElement(railType.PrimaryHandrailType))
lst.append(doc.GetElement(railType.SecondaryHandrailType))
lst.append(doc.GetElement(railType.TopRailType))
OUT = lst
-biboy
Thank you very much for response, not exactly want I want, but you gave me a clue how it should looks like! When I’m implementing this code, I receive TypeId. And when I’m trying to get Lenght, I receive nulls
I don’t need the Type of element, I need its as element geometry to catch length then. Wouldn’t it be insolent to ask you take a look at my variant? I have en error ‘NoneType’ object has no attribute “AsString”
lst = list()
rLength = doc.GetElement(railing.get_Parameter(BuiltInParameter.CONTINUOUSRAIL_LENGTH_PARAM).AsString())
lstl = llist()
lstl.append(railLength)
lstl.append(doc.GetElement(rLength.PrimaryHandrailLength))
lstl.append(doc.GetElement(rLength.SecondaryHandrailLength))
lstl.append(doc.GetElement(rLength.TopRailLength))
OUT = lst, lstl
Please mark my solution as the solution to your original question because I think I have solved it. For another question not related or a question supplementary to your original question, please make another topic about it.
