Python Script to Extract Polyline X, Y Values
Yes. You are correct! My bad. I forgot closing the polyline changes the indexes. Fixed with a simple if statement:
ExtractPoints.dyn (8.0 KB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.DesignScript.Geometry import Point
dataEnteringNode = IN
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            errorReport = None
            try:
                polyLineList = []
                selectedPolylines = IN[0]
                for polyline in selectedPolylines:
                    polyLinePoints = []
                    realObject = polyline.AcObject
                    if isinstance(realObject, Polyline):
                        if realObject.Closed:
                            indexNum = int(realObject.EndParam)
                            indexNum = int(realObject.EndParam)+1
                        for i in range(indexNum):
                            point = realObject.GetPoint2dAt(i)
                            polyLinePoints += [[point.X,point.Y]]
                        polyLineList += [polyLinePoints]
            except:
                import traceback
                errorReport = traceback.format_exc()
            # Commit before end transaction
            t.Commit()
if errorReport == None:
    OUT = polyLineList
    OUT = errorReport
That works - thank you! Do you think it is possible to get the output of your script to run into the a script I already put together to remove excess x and y vertices for these shapes? I am not sure how to get these nested x and y values into the script I already put together. Node with the python script I created is attached.
Remove excess x and y vertices.dyn (3.9 KB)
A solution using ProtoGeometry (purge points by comparing 2 successive vectors)
remove extras points
import sys
clr.AddReference('Python.Included')
import Python.Included as pyInc
path_py3_lib = pyInc.Installer.EmbeddedPythonHome
sys.path.append(path_py3_lib + r'\Lib\site-packages')
import numpy as np
            errorReport = None
            try:
                polyLineList = []
                    polyLinePoints = []
                    pline = polyline.AcObject
                    if isinstance(pline, Polyline):
                        pline = t.GetObject(pline.ObjectId, OpenMode.ForWrite)
                        purgeDSPts = []
                        arr_del_idx = np.array([])
                        # convert all points to Proto
                        DSPoints = [DS.Point.ByCoordinates(pline.GetPoint3dAt(i).X,
                                                            pline.GetPoint3dAt(i).Y,
                                                            pline.GetPoint3dAt(i).Z) \
                                                            for i in range(pline.NumberOfVertices)]
                        # purge points by comparing 2 successive vectors
                        purgeDSPts = [DSPoints.pop(0), DSPoints.pop(0)]
                        start_idx = len(purgeDSPts) - 1
                        for idx, pt in enumerate(DSPoints):
                            vectA = DS.Vector.ByTwoPoints(purgeDSPts[-2], purgeDSPts[-1])
                            vectB = DS.Vector.ByTwoPoints(purgeDSPts[-1], pt)
                            if vectA.IsParallel(vectB):
                                # replace the last point
                                purgeDSPts[-1] = pt
                                # add index to delete
                                arr_del_idx = np.append(arr_del_idx, [start_idx + idx ])
                                purgeDSPts.append(pt)
                        # remove extras points
                        while len(arr_del_idx) > 0:
                            # get the first and remove it from the np array
                            del_idx, arr_del_idx = arr_del_idx[0], arr_del_idx[1:]
                            print(del_idx)
                            pline.RemoveVertexAt(del_idx)
                            # decrement all index in np array
                            arr_del_idx -= 1
            except:
                import traceback
            t.Commit()
    OUT = purgeDSPts
    OUT = errorReport
This looks awesome! Thank you!
I am running into an error when I try it myself, though. Screenshot below. Any thoughts?
Since application is not called on line 5, I think it safe to say you missed your imports when copying the code above.
you are right - i don’t know how I did get all of the code copied over. Thank you!!!
Honestly I do the same thing 2x a day, so I only was able to pick up on it because of my own familiarity with the issue… and I’m usually moving from notepad where ctrl+a ctrl+c prevents it rather than the forum…
