Python IndexError
Not sure what’s going on here.
First, why I’m getting an error in a line that doesn’t exist?
And second, Why I’m getting that error?
The first while loop works fine. I’m getting a list (distList) with 7 items, so, count1 is 7.
The line number on the error message will usually return the line number that is 1 greater than where the line is (though it can be more if your code uses definitions to execute). In this case the error is on line 20.
I think this error is happening because you’re asking Python to find the item at index zero, when such a thing doesn’t exist, as repDist is an empty list. It would be like asking me what the first thing on my shopping list for next weekend is today - I have the paper set up to write it, but it’s blank, so I can’t tell you what that will be yet. Actually, that will be coffee… it’s always coffee. Ask me for the second item though and that’s a complete unknown.
Kidding aside, try changing line 19 to repDist = [ distList [0] ] and skip line 20 entirely, that should give you your first value from the distList as the first value in your repDist when you define it.
Thanks again Jacob. It worked!!!
I liked your example, tho
