When I run the graph I’m getting an error: AttributeError: ‘NoneType’ object has no attribute ‘Name’ in line 40. I retyped it from the image in the original post and skimped on some of the comments but as far as I could tell the code itself is the same. Has there been a backend change that would affect the i.Name section of the code or did I just do something wrong? Any advice on a fix is most appreciated.
The output of Id to Element is a list of nulls… Let me try it a little differently and see what happens.
edit: slight revision to the Id to Element node (added the python back in to convert to integers) fixed the null error but it created another error:
File "<string>", line 40, in <module>
Exception: Name must be unique.
Parameter name: name
There are duplicate names in the fill pattern list but that is because there are Model patterns & Drafting patterns. In that case would I need to split the list and run it twice?
I just looked and the renaming worked, at least as far as I can tell. There were 2 model patterns with a similar name other than capitalization: Louver & LOUVER - they could have been the culprit as well.
@luupieper
I honestly have no idea…
If it helps at all, I’m including a graph that I’m pretty sure gets the end result I was looking for in the original post.
Thanks a lot, Chad! In the end, I found out that the problem (at least for me) was that I was calling a parameter that has its value defined by another parameter
