Python - Get Coordinate from point
I need to get the coordinate of a point.
The result I get with my script is:
<Autodesk.DesignScript.Geometry.Point object at 0x0000000000004B23 [Point(X = -11.987, Y = 15.666, Z = 10.000)]>]
But I need:
How can I get this?
Thank you in advance!
Can you show us how you’re getting this output? It looks more like a string than an object.
for room in rooms:
    #t.Start()
    room_loc = room.Location.Point
    boundaries = room.GetBoundarySegments(SBO)
    segGroup = []
    for bound in boundaries:
        pGroup=[]
        cLoops=[]
        for seg in bound:
            pGroup.append(seg.GetCurve().GetEndPoint(0).ToPoint())
   print(pGroup)
Ah. Looks like you’re using print instead of OUT. Print will log the output to the console. OUT will return the objects at the python node.
I am not using dynamo actually. I am running directly with python. Maybe that´s the problem.
Hmm. It’s still weird that it returns a description of the object.
Try printing the points individually instead of as a list.
I did that but the ouput is:
Point(X = -11.987, Y = 17.666, Z = 2.500)
I need:
(-11.987, 17.666, 2.500)
for room in rooms:
    #t.Start()
    segGroup = []
    print(room_loc)
        pGroup=[]
        cLoops=[]
        for seg in bound:
            for p in pGroup:
                print(p)
You should just need to convert them to Revit XYZs.
I got it.
I need to append:
 pGroup.append(seg.GetCurve().GetEndPoint(0))
and not
for room in rooms:
    #t.Start()
    segGroup = []
    print(room_loc)
        pGroup=[]
        cLoops=[]
        for seg in bound:
            for p in pGroup:
                print(p)
This way I get: (-11.987, 17.666, 2.500)
Makes sense, obviously. :open_mouth:
Thanks for your help Nick :slight_smile:
Out of curiosity you can reveal your beginning of code
it appears to be a memory stored object returned every time with the class
(I’m not strong, the terms are not necessarily the right ones)
cordially
christian.stan
