Seems that I am inputting the right element (document). Has anybody else seen this issue?
UnwrapElement maybe?
Are you using the current document only? If so, I would define this in python by…
And this would be written just below where you import the document manager.
Yes I am. I am just getting into Phython and learning the ropes.
I am modifying a snippet taken from a node that was accessing LInked Docs.
I had a feeling that there was a different way to call up the current doc I will test this and let you know, but I am pretty sure you just answered my quesiton!
Right On Daniel! That worked…
Thank both of you for your responses!
You’re welcome!
Glad you got your problem solved! I suggest editing your post title to “Python Error: Expected Document, Got Document” so it will show up in search results if someone has the same issue in the future
done deal!
