Python Error - Could not add reference to assembly ProtoGeometry
I’m using the python script & graph referenced in the following threads:
http://dynamobim.com/forums/topic/create-sheetset-from-sheet-grouping/
http://dynamobim.org/forums/topic/create-sheetset-print-set-from-specified-revision/
Up until today it was working beautifully, but when I tried to run the script a few minutes ago I get an error from the Python node:
File “”, line 2, in
IOError: System.IO.IOException: Could not add reference to assembly ProtoGeometry
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, String name)
at IronPython.Runtime.ClrModule.AddReference(CodeContext context, Object references)
Lines 1-3 of the script:
I’m totally lost on what to do with this one.
thanks
edit:
The error is popping up on any python node that references ProtoGeometry
revised post title.
Hi Chad,
Are you trying to use Python script in Dynamo Studio?
Not that I know of :worried:
Revit (2016) -> addins -> Dynamo
Maybe you have to reinstall Dynamo? Have you got a ProtoGeometry.dll in …\Dynamo Core\1.0 ?
ProtoGeometry.dll is in the directory.
I’ll give reinstalling a shot.
It took a full uninstall of both Dynamo & Dynamo Core but it is working now.
Thanks for the assist! :grin:
Does anyone have an idea as to why this is happening?
I had the same issue this morning. The .dll is there but “ProtoGeometry” fails every time. I actually got the python script to run by removing those few lines. I’ll try reinstalling later.
