hello, I am trying to get rid off the absolute value, but I don’t understand why I am getting error
xVal = IN[0]
xout=
for x in xVal:
b = abs(x):
if b<150:
xout.append("Less than 150 Pipe is " + str(b))
xout.append('Cool keep going ’ + str(b))
OUT = xout
@abdu2736 what’s the error?
i already tried that but still the same
Alright, so like Salvo said: what’s the error message?
You need to indent line 4, and then further indent the following lines
hi martin not sure if I understand it can you please rearrange it for me:
xVal = IN[0]
xout=[]
for x in xVal:
b = abs(x)
if b<150:
xout.append('Cool keep going ' + str(b))
OUT = xout
File “”, line 4, in
TypeError: bad operand type for abs(): ‘NoneType’
are the values in “x” strings? They need to be numbers.
@abdu2736
xVal = IN[0]
xout=[]
for x in xVal:
b= abs(x)
if b<150:
OUT = xout
thank you i think the problem was it because of the null value, but all is good now
