Im only use a class for one problem and create for 1 node .
try removing the “.” from the name space and give your namespace a name that is the same or close to your assembly name
I tried . and remove .MEP But Same Problem
then i think you can create another “baseclass” that inherits RevitDropDownBase queries all the element type based on the type that it is fed.
try this:
[NodeName("Duct Types")]
[NodeDescription("Get All Duct Type From Model Dropdown")]
[NodeCategory("DynaMEP.MEP.Ducts")]
[IsDesignScriptCompatible]
public class DuctTypes : GenericGetAllElementOfTypeDropDown
private const string outPutName = "Duct Type";
private const string NO_DUCT_TYPES = "No Duct Types Found.";
public DuctTypes() : base(outPutName, NO_DUCT_TYPES, typeof(DuctType)) { }
[JsonConstructor]
public DuctTypes(IEnumerable<PortModel> inPorts, IEnumerable<PortModel> outPorts) : base(outPutName, NO_DUCT_TYPES, typeof(DuctType), inPorts, outPorts) { }
public class GenericGetAllElementOfTypeDropDown : RevitDropDownBase
private string NO_TYPE_FOUND { get; set; } = "No Type Found";
private Type ClassType { get; set; }
private SelectionState _selectionState = SelectionState.Done;
public GenericGetAllElementOfTypeDropDown(string name, string noEnumFound, Type enumType) :
base(name)
this.ClassType = enumType;
this.NO_TYPE_FOUND = noEnumFound;
PopulateDropDownItems();
[Newtonsoft.Json.JsonConstructor]
public GenericGetAllElementOfTypeDropDown(string name, string noEnumFound, Type enumType, IEnumerable<PortModel> inPorts, IEnumerable<PortModel> outPorts) :
base(name, inPorts, outPorts)
public void PopulateDropDownItems()
if (this.ClassType != null)
// Clear the dropdown list
Items.Clear();
Items.Clear();
Dictionary<int, string> eleNameInt = new Dictionary<int, string>();
using (FilteredElementCollector col = new FilteredElementCollector(DocumentManager.Instance.CurrentDBDocument).OfClass(typeof(DuctType)))
var eles = col.ToElements();
if (!eles.Any())
Items.Add(new DynamoDropDownItem(NO_TYPE_FOUND, null));
SelectedIndex = 0;
foreach (var ele in eles)
eleNameInt.Add(ele.Id.IntegerValue, ele.Name);
Items = eleNameInt.Select(x => new DynamoDropDownItem(x.Value, x.Key)).OrderBy(x => x.Name).ToObservableCollection();
_selectionState = SelectionState.Restore;
protected override SelectionState PopulateItemsCore(string currentSelection)
return _selectionState;
public override IEnumerable<AssociativeNode> BuildOutputAst(List<AssociativeNode> inputAstNodes)
if (!CanBuildOutputAst(NO_TYPE_FOUND))
return new[] { AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), AstFactory.BuildNullNode()) };
List<AssociativeNode> args = new List<AssociativeNode>()
AstFactory.BuildIntNode((int)Items[SelectedIndex].Item),
AstFactory.BuildBooleanNode(true),
Func<System.Int32, System.Boolean, Revit.Elements.Element> func = new Func<System.Int32, System.Boolean, Revit.Elements.Element>(Revit.Elements.ElementSelector.ByElementId);
AssociativeNode callFunctionNode = AstFactory.BuildFunctionCall<System.Int32, System.Boolean, Revit.Elements.Element>(
Revit.Elements.ElementSelector.ByElementId,
args
BinaryExpressionNode assign1 = AstFactory.BuildAssignment(GetAstIdentifierForOutputIndex(0), callFunctionNode);
return new[]
assign1
bool CanBuildOutputAst(string itemValueToIgnore = null, string selectedValueToIgnore = null)
if (Items.Count == 0 || SelectedIndex < 0)
return false;
if (!string.IsNullOrEmpty(itemValueToIgnore) && Items[0].Name == itemValueToIgnore)
return false;
if (!string.IsNullOrEmpty(selectedValueToIgnore) && Items[SelectedIndex].Name == selectedValueToIgnore)
return false;
return true;
Same Problem
The ‘+’ character, hexadecimal value 0x2B, cannot be included in a name
