Ok - so we have the right Python version. That’s the first step. Next up which Crumple version are you on?
Sorry you’re struggling here. I feel bad but it’s important for everyone to try and understand ‘why’. It’s not a Gavin thing, or a Revit thing, or a Dynamo thing, or a Python thing, but the nature of technology. The issues stem from referring to old workflows/code in new tools. Basically you need to revise the workflow for the .NET upgrade (4.8 to 8), Python upgrade (2.7 to 3.9), and Revit upgrade (2025 vs 2022). If that sounds like a lot of changes… well it is a TON. It’s like trying to play a song where part of the track is on an 8 track, part on a cassette, and part on a CD and the only speakers you have are attached to a modern car stereo.
Crumple Version 2024.4.3 its noted that it is only built for Revit 2022 and Dynamo 2.12. It would make sense if this was the issue.
That node uses winforms which are not supported in 2025/net core to my understanding, at least in the way that node is set up.
I build in 2022, and have tested most nodes in 23/24 but not many in 2025. Havent had time at this point unfortunately, my focus is currently on C# and addin development.
Here is a fixed version of UI.DropdownForm node that is compatible with :
- CPython3
- IronPython3
- PythonNet3
code
# Made by Gavin Crump
# Free for use
# BIM Guru, www.bimguru.com.au
# Thanks for the tips and example Cyril!
# https://github.com/Cyril-Pop/IronPython-Samples/blob/master/WinForms/combobox%2BDataBinding%20with%20DataTable.py
import System
from System import Array
from System.Collections.Generic import List, IList, Dictionary
clr.AddReference('System.Data')
from System.Data import *
clr.AddReference("System.Drawing")
clr.AddReference("System.Windows.Forms")
import System
import System.Drawing
from System.Drawing import *
from System.Windows.Forms import *
# Define list/unwrap list functions
def tolist(input):
result = input if isinstance(input, list) else [input]
return result
# Imports from Dynamo
form_title = IN[0]
keys = tolist(IN[1])
values = tolist(IN[2])
form_width = IN[3]
form_height = IN[4]
# Class for main winform
class MainForm(Form):
# Initialize form object
def __init__(self, keys, values, title, formWidth, formHeight):
super().__init__()
self.title = title
self.formWidth = formWidth
self.formHeight = formHeight
self._table = DataTable("DataTable")
self._table.Rows.Add() # to add a empty row
self._table.AcceptChanges() # to add a empty row
self._table.Columns.Add("Key", System.String)
self._table.Columns.Add("Value", System.Object)
for k_, v_ in zip(keys, values):
self._table.Rows.Add(k_, v_)
self.choice = None
self.Font = System.Drawing.SystemFonts.DefaultFont
self.InitializeComponent()
# Make form components
def InitializeComponent(self):
# Add buttons
self._comboBox = System.Windows.Forms.ComboBox()
self._buttonCancel = System.Windows.Forms.Button()
self._buttonOK = System.Windows.Forms.Button()
self.SuspendLayout()
# Combo box
self._comboBox.Anchor = System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left | System.Windows.Forms.AnchorStyles.Right
self._comboBox.Location = System.Drawing.Point(20, 20)
self._comboBox.Size = System.Drawing.Size(self.formWidth - 40, 21)
self._comboBox.DataSource = self._table
self._comboBox.DisplayMember = "Key"
self._comboBox.ValueMember = "Value"
self._comboBox.SelectedIndexChanged += self.ComboBox1SelectedIndexChanged
# OK button
self._buttonOK.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right
self._buttonOK.Location = System.Drawing.Point(self.formWidth-180, self.formHeight-50)
self._buttonOK.Name = "buttonOK"
self._buttonOK.Size = System.Drawing.Size(80, 25)
self._buttonOK.TabIndex = 1
self._buttonOK.Text = "OK"
self._buttonOK.UseVisualStyleBackColor = True
self._buttonOK.Click += self.ButtonOKClick
# Cancel button
self._buttonCancel.Anchor = System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right
self._buttonCancel.Location = System.Drawing.Point(self.formWidth-100, self.formHeight-50)
self._buttonCancel.Name = "buttonCancel"
self._buttonCancel.Size = System.Drawing.Size(80, 25)
self._buttonCancel.TabIndex = 1
self._buttonCancel.Text = "Cancel"
self._buttonCancel.UseVisualStyleBackColor = True
self._buttonCancel.Click += self.ButtonCancelClick
# Draw main form
self.ClientSize = System.Drawing.Size(self.formWidth, self.formHeight)
self.MinimumSize = System.Drawing.Size.Add(self.ClientSize, System.Drawing.Size(20, 20))
self.Controls.Add(self._comboBox)
self.Controls.Add(self._buttonOK)
self.Controls.Add(self._buttonCancel)
self.ControlBox = False
self.SizeGripStyle = System.Windows.Forms.SizeGripStyle.Show
self.Name = "MainForm"
self.Text = self.title
self.BringToFront()
self.CenterToScreen()
# self.FormBorderStyle = FormBorderStyle.FixedSingle
self.ResumeLayout(False)
# Event if dropdown changes
def ComboBox1SelectedIndexChanged(self, sender, e):
if isinstance(sender.SelectedItem['Value'], System.DBNull):
self.choice = None
self.choice = sender.SelectedItem['Value']
# Event if OK button pressed
def ButtonOKClick(self, sender, e):
self.Close()
self.runNextOutput = True
def ButtonCancelClick(self, sender, e):
self.choice = None
self.Close()
self.runNextOutput = False
# Show form to the user
objForm = MainForm(keys, values,
title = form_title,
formWidth = form_width,
formHeight = form_height)
objForm.ShowDialog()
# Return the selected object and if it was cancelled
chosenItem = objForm.choice
if not chosenItem:
OUT = None, True
OUT = chosenItem, False
