Prevent overwriting results
I placed two Families in my Revit document using a Dynamo script. Now I want to ad a third Family using the same script. Running the script results in losing the first two Families and getting one in return which is placed.
Is there a way to disconnect the first two Families from the script and by running the script again getting a third Family (with the same name as the former once) placed in my Revit document?
I have tried to get the wanted results by saving the Revit document and open it again and Run the Dynamo script.
Also I have renamed the Dynamo script and opend the renamed script in Revit but the result is still the same.
Search button works really nice :smiley:
Create python node and copy-paste code from:
@Tomasz_Puchala
Thank you for your reply and the link.It is the wright solution.
