Hello everyone,
As you can see in the title, I am trying to copy one element instance several times at the same location. In order to do so, I looked for the command “Aligned to Same Place” in the Revit API.
I would need some aid as I do not know how to interpret that API command in a Python node. I tried to do the following with no success.
Any kind of suggestion?
Thank you so much.
from Autodesk.DesignScript.Geometry import
clr.AddReference("RevitAPI")
uidoc = DocumentManager.Instance.CurrentUIDocument
clr.AddReference("System.Core")
from System.Collections.Generic import HashSet
def tolist(obj1):
if hasattr(obj1,"__iter__"): return obj1
else: return [obj1]
# IN variables...
run = tolist(IN[0])[0]
elems = tolist(UnwrapElement(IN[1]))
# Main Code...
if run:
# Get ElementIds to list...
elemIds = HashSet[ElementId]([e.Id for e in elems])
# Set Selection (required for the postable command)...
uidoc.Selection.SetElementIds(elemIds)
uidoc.RefreshActiveView()
# Get RevitCommandId of PostableCommand...
rvtComId = Autodesk.Revit.UI.PostableCommand(PostableCommand.AlignedToSamePlace)
# Run PostableCommand...
uiapp.PostCommand(rvtComId)
OUT = "Command Has Run"
OUT = "Please set Run to True"
You may want to explore using a different workflow from PostCommand, as this is still limited to a ‘run one’ process and doesn’t like being chained as part of a workflow.
Exception: Revit does not support more than one command are posted.
Using the copy and paste-aligned commands is entirely possible.
Kind of a forced-run though, as I ran once to copy then (I used + to add an input to the Paste node) and ran again to paste.
Copy Code
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Events import DialogBoxShowingEventArgs
clr.AddReference('System')
from System.Collections.Generic import List as sList
def tolist(obj1):
else: return [obj1]
# IN variables...
empty = sList[ElementId]()
# Main Code...
if run:
# Get Revit Command Id
rvtCmdId_Copy = RevitCommandId.LookupCommandId('ID_EDIT_COPY')
# Run Command
uiapp.PostCommand(rvtCmdId_Copy)
uidoc.Selection.SetElementIds(empty)
OUT = elems
Paste Code
def tolist(obj1):
else: return [obj1]
# IN variables...
# Main Code...
if run:
rvtCmdId_PasteAligned = RevitCommandId.LookupCommandId('ID_EDIT_PASTE_ALIGNED_SAME_PLACE')
# Run Command
uiapp.PostCommand(rvtCmdId_PasteAligned)
OUT = "New Elements Pasted Aligned"
CopyPaste.dyn (12.4 KB)
Tip: If you ever need to know the command name for something that you have just done in Revit, look in the journal files.
