Pop up message
Hello guys,
Do you know any package that contains message pop up nodes for dynamo 2.0…?
I use Battle BIM for dynamo 1.3.3 but it has not been upgrade yet.
Many thanks
Data-Shapes from @Mostafa_El_Ayoubi.
Thanks John!!!
I couldn’t find any but I’ll have another look.
I also have simple user messages in Rhythm
@BIMadmin
Morning Salvatore,
I give it a go in Dyn 1.3.3 and 2.0.2 but did not work
Do you know why?
Many thanks
Hello John,
The one from your package works really well,
I am just curious which one from datashapes does the same job?
I cannot find it
Many thanks
@BIMadmin, you may want to have a look at the blog posts about data shapes to help decide on which one to use.
Hello Brendan,
Thanks for this but if we use data shapes the popup window will expect us to feed the input.
I don’t think there is a specific node in the package that pop up with a message.
In Data-Shapes you have a “kit of parts” to construct your own UI.
this works:
If true you get a popup
jejeje,
Thanks John, you are awesome!!!
@BIMadmin it looks okay. Can you post you dyn?
Sure Salvatore,
Here it isPop up message.dyn (2.3 KB)
Many thanks!!
@BIMadmin I get a different error but anyway the problem is the indentation inside the function
Thanks Salvatore,
Then the solution here is to modify the indentation of the line below the Def?
Correct. You can’t use different indentation in different rows. Did it work for you?
Yes Salvatore,
Many thanks!!!
