I’ve been trying to make a script which will turn on many detail groups from several model groups in a series of views. I have everything up to the very final step which I cannot figure out. I’ve found several topics on here and tried the nodes/code but to no avail. I’ve tried doing it with chatGPT and also asked it to modify the other examples but nothing I got would work for me.
Below is the last portion of my script where I have lists for all views, all groups and all detail groups. I’ve also attached the script although it might be slightly specific and not work?
I had a little time this afternoon, togther with chatGPT I managed to figure this out, code below
# --- Import Revit and Dynamo API dependencies ---
import sys
# Add .NET assembly references for Revit API access via pythonnet
clr.AddReference("RevitAPI")
# --- Revit API Imports ---
# --- Dynamo Revit Wrappers ---
clr.ImportExtensions(Revit.Elements) # Enables UnwrapElement() and other helpers
# --- Dynamo Revit Services ---
# --- INPUTS ---
# IN[0] -> list of lists of model groups (each sublist corresponds to a view)
# IN[1] -> list of lists of lists of detail groups (sublist per model group, per view)
# IN[2] -> list of views (one per outer list)
modelGroups = UnwrapElement(IN[0])
detailGroups = UnwrapElement(IN[1])
views = UnwrapElement(IN[2])
# --- DOCUMENT REFERENCE ---
# --- START TRANSACTION ---
# --- SAFETY CHECK ---
# Ensure all inputs are present and non-empty
if not (modelGroups and detailGroups and views):
OUT = "One or more inputs are empty or invalid."
# --- MAIN LOGIC LOOP ---
# Iterate through each view with its corresponding model groups and detail groups
for v, modelList, detailLevelList in zip(views, modelGroups, detailGroups):
# Iterate through each model group and its corresponding list of detail groups
for m, detailSubList in zip(modelList, detailLevelList):
# Iterate through each individual detail group for this model group
for d in detailSubList:
# Show the attached detail group in the specified view
m.ShowAttachedDetailGroups(v, d.Id)
# --- END TRANSACTION ---
# --- OUTPUT ---
# Return the original model groups back to Dynamo for reference
OUT = IN[0]
