I have a problem with the placement of a 3D Sectionbox I created from room boundingbox.
I am using a Python Script to place the views. It works with floorplans and elevations. But not with the Sectionboxes. I am not that good at Python, so troubleshooting is a bit difficult for me.
HI @MadsMartiny
by using .Id the element id gets retrieved and output as an integer, but according to Reivt API the element id as an object must be passed to the method.
knowing that, the element id can be easily converted into an object as done in the code.
clr.AddReference("RevitAPI")
view = IN[0]
sheet = IN[1]
view_id = ElementId(view.Id)
sheet_id = ElementId(sheet.Id)
OUT = Viewport.Create(doc, sheet_id, view_id, XYZ(0,0,0))
Thanks.
First I actually tried just to remove the line, which created the error, and then copied it back. Then it actually worked.
But I also tried yours and also did the job.
Thanks for the answer
