Thank you very much for your help and inspire me JacobSmall. The problem in the end was of my families that with “Boundingbox” does not work if I had to do it this way but if it is not for you I would not find where the problem is or how to solve it. Thank you so much
As I get older I have another problem that I already saw that there are many posts but in this case it does not work. I need to split the pipe but if I delete and create another one like in these posts “Split Geometry At a given length” I lose the connection of the “spudperpendicular”.
Can’t cut the existing pipe? or join the spudperpendicular later? With the MEPOver py join the elbows but not the spudperpendicular.
Thank you very very much
