Hi, is it possible to access to : PathOfTravelCalculationStatus enumeration value ?
Daniel OLIVES
I come until here…
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Analysis import *
clr.AddReference('System')
routeSettings = RouteAnalysisSettings.GetRouteAnalysisSettings(doc)
path = FilteredElementCollector(doc).OfClass(Analysis.PathOfTravel).ToElements()
way = UnwrapElement(path)
OUT = path, way
Yes. Load in the Autodesk.Revit.DB.Analysis class and you should be able to access the enumeration directly.
Hy, Thank for the answer
Daniel
L_Durée, L_Vitesse, L_Niveaux, L_Vues, L_HabOrigine, L_HabDestination, L_Status = [],[],[],[],[],[],[]
for r in paths :
temps = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_TIME).AsDouble()
L_Durée.append(temps)
vitesse = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_SPEED).AsDouble()
# avant Revit 2022
#vitesse.append(UnitUtils.ConvertFromInternalUnits(vitesse, DisplayUnitType.DUT_KILOMETERS_PER_HOUR))
# à partir de Revit 2022
L_Vitesse.append(UnitUtils.ConvertFromInternalUnits(vitesse,UnitTypeId.KilometersPerHour))
niveaux = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_LEVEL_NAME).AsString()
L_Niveaux.append(niveaux)
vues = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_VIEW_NAME).AsString()
L_Vues.append(vues)
origine = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_FROM_ROOM).AsString()
L_HabOrigine.append(origine)
destination = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_TO_ROOM).AsString()
L_HabDestination.append(destination)
status = PathOfTravelCalculationStatus(r)
# L_Status.append(status)
OUT = paths, L_Durée, L_Vitesse, L_Niveaux, L_Vues, L_HabOrigine, L_HabDestination#, L_Status
Hi, Andrea and Jacob
Here i my code, but for status i have an error.
TypeError : cannot instantiate enumeration
in ligne: status = PathOfTravelCalculationStatus(r)
Dynamo 2.16 - Revit 2023.1
Daniel
Why do you need the enumeration values?
Hi, thank’s it’s just a test to extract this value !
The Status of the path
Daniel
