Parsing a List with 'Build Sublists'
'Build Sublists' offers a way to customize how a list can be parsed into nested sublists using a parsing syntax.
Example 1... the syntax "0..1" means to get items 0-1 from the list... the offset input tells the node to repeat the same operation 2 items further down the list. The node will then iterate over the entire sequence.
Example 2... the syntax "0..a" will create an additional Node input for variable a so you can control the parsing with other nodes.
ok thx, but you use the list. what are spline meant for?
use reference points and curve by points,
see image
thank you for this explanation; somehow a bit hard to learn Dynamo alone....
one question: how can I turn Hermite spline into a curve? can't find how?
