Parameter.create error
hello everyone. I just want to put parameter on several Families. But Parameter.Create have some error.
I want to use type parameter.create ( occur error )
But another Parameter.Create(Use Categories) work well…
I don’t know why this happen…
I use Revit 2022, Dynamo 2.10
The error was this… i don’t understand…
I’m guessing that comes from a package you installed. An educated guess says that the node is using an API method that is obsolete as of Revit 2022. Check for an update to the package.
Yes… you are right
My dynamo version was 2.10, but Orchid for 2.12
So, I changed my dynamo version 2.12 as updating Revit 2022.1. and it worked
Thank you!
