Overriding REVIT prompt in Dynamo
CeilingPlan.ByRoom:
You would need to find the “FloorPlan” references and change them to “CeilingPlan”
Here is from the Original Node:
Here are the edits to make ceiling plans:
The inputs remain the same as the original node:
Copyright(c) 2015, Konrad K Sobon
# Import Element wrapper extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
from System import Array
sys.path.append(pyt_path)
dataEnteringNode = IN
if isinstance(IN[0], list):
rooms = UnwrapElement(IN[0])
rooms = [UnwrapElement(IN[0])]
namePrefix = IN[1]
bboxOffset = IN[2]
runMe = IN[3]
def OffsetBBox(bbox, offset):
bboxMinX = bbox.Min.X - offset
bboxMinY = bbox.Min.Y - offset
bboxMinZ = bbox.Min.Z - offset
bboxMaxX = bbox.Max.X + offset
bboxMaxY = bbox.Max.Y + offset
bboxMaxZ = bbox.Max.Z + offset
newBbox = BoundingBoxXYZ()
newBbox.Min = XYZ(bboxMinX, bboxMinY, bboxMinZ)
newBbox.Max = XYZ(bboxMaxX, bboxMaxY, bboxMaxZ)
return newBbox
try:
errorReport = None
if runMe:
viewTypes = FilteredElementCollector(doc).OfClass(ViewFamilyType)
for i in viewTypes:
if i.ViewFamily == ViewFamily.CeilingPlan:
viewTypeId = i.Id
break
continue
existingPlans = FilteredElementCollector(doc).OfClass(View).ToElements()
existingPlanNames, existingPlanElements = [], []
for i in existingPlans:
if not i.IsTemplate:
if i.ViewType == ViewType.CeilingPlan:
existingPlanNames.append(i.ToDSType(True).Name)
existingPlanElements.append(i)
# Start Transaction
floorPlans = []
cropBoxes = []
for i in rooms:
levelId = i.LevelId
bbox = i.BoundingBox[doc.ActiveView]
newBbox = OffsetBBox(bbox, bboxOffset)
cropBox = OffsetBBox(bbox, -bboxOffset)
viewName = namePrefix + " A-PP" + i.get_Parameter(BuiltInParameter.ROOM_NUMBER).AsString() + " (" + i.get_Parameter(BuiltInParameter.ROOM_NAME).AsString()+ ")"
if viewName in existingPlanNames:
view = existingPlanElements[existingPlanNames.index(viewName)]
view.CropBox = newBbox
view.CropBoxActive = True
view.CropBoxVisible = False
floorPlans.append(view)
newView = ViewPlan.Create(doc, viewTypeId, levelId)
newView.ViewName = viewName
newView.CropBox = newBbox
newView.CropBoxActive = True
#view.CropBoxVisible = False
floorPlans.append(newView)
# End Transaction
errorReport = "Run Me set to False"
except:
# if error accurs anywhere in the process catch it
import traceback
#Assign your output to the OUT variable
if errorReport == None:
OUT = floorPlans
OUT = errorReport
