Organizing/Ordering Points for Polygon
Another thing you could try is the “LineLoop.Merge” node from springs. It should act similar to Vikram’s solution:
Just for fun I used TuneUp to check on all the speeds of these solutions (If performance will be an issue) and you get as follows:
Note: The millisecond execution numbers do jump around a little (+/- 15ms) so take them all with a little grain of salt.
Short answer is they are all awesome solutions :smiley:
a small variant :upside_down_face:
import sys
import itertools
clr.AddReference('RevitAPI')
def customIntersectAll(*args):
    if sys.implementation.name == 'ironpython':
        for curveA, curveB in itertools.product(*args):
            interResultArray = clr.Reference[IntersectionResultArray]()
            compareResult = curveA.Intersect(curveB, interResultArray)
            if compareResult == SetComparisonResult.Overlap:
                yield(interResultArray.Value[0].XYZPoint )
            outInterResultArrayout = IntersectionResultArray()
            compareResult, interResultArray = curveA.Intersect(curveB, outInterResultArrayout)
                yield(interResultArray[0].XYZPoint)
def isParallelOverlap(c1, c2):
    v1 = c1.Direction.Normalize()
    v2 = c2.Direction.Normalize()
    check1 = c1.Intersect(c2) == SetComparisonResult.Equal
    check2 = v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0, 0, 0))
    return all([check1, check2])
def sortPoint(lstPts, orderPts = []):
    global lstCurveA
    if len(orderPts) == 0:
        orderPts.append(lstPts.pop(0))
    lstPts.sort(key = lambda x : x.DistanceTo(orderPts[-1]))
    for idx, pta in enumerate(lstPts):
        lineAB = DB.Line.CreateBound(pta, orderPts[-1])
        if any(isParallelOverlap(c, lineAB) for c in lstCurveA):
            orderPts.append(lstPts.pop(idx))
            lineAB.Dispose()
            return sortPoint(lstPts, orderPts)
    return [x.ToPoint() for x in orderPts]
lstRvtLines = UnwrapElement(IN[0])
lstCurveA = [x.Location.Curve for x in lstRvtLines]
lstCurveB = lstCurveA[:]
outPoint = []
for pt in customIntersectAll( lstCurveA, lstCurveB):
    if all(not pt.IsAlmostEqualTo(x) for x in outPoint):
        outPoint.append(pt)
OUT = sortPoint(outPoint)
see also this post
Organizing/Ordering Points for Polygon - #27 by c.poupin
A way with nodes, not so stable as @c.poupin, @Vikram_Subbaiah, @Dimitar_Venkov amazing methods but will work in this case…
This is another option with Nodes :slight_smile: Around 65ms, but is caveated: Will only work on the proviso that when you split lines you want to keep the longest one.
Zakim_OrderingPointsForPolygon.dyn (28.9 KB)
Thank @c.poupin for sharing this solution. It is a great help.
So I finally had sometime to play with it. For some reason, I am getting points out of sequence when one of the edges are long.?!
because the script searches for the nearest point for each point
you can try this version of python code
import sys
import itertools
import System
	return all([check1, check2]), v1
def allVectorsAreParallel(lstPairBool_Vect):
	check if all vector are parallel
	input Parameter -> [[bool, vector], [bool, vector], ...]
	lstVect = [v[1] for v in lstPairBool_Vect if v[0]]
	v1 = lstVect.pop(0)
	for v2 in lstVect:
		if not v1.CrossProduct(v2).IsAlmostEqualTo(XYZ(0, 0, 0)):
			return False
	return True
	sort points by intersection/overlap curves
	global lstCurveA
	# 1st pass
	lstPts.sort(key = lambda x : x.DistanceTo(orderPts[-1]), reverse = True)
		lstPairBool_Vect = [isParallelOverlap(c, lineAB) for c in lstCurveA]
		if sum(c[0] for c in lstPairBool_Vect) == 1:
			lineAB.Dispose()
	# 2nd pass
		if sum(c[0] for c in lstPairBool_Vect)  > 1 and allVectorsAreParallel(lstPairBool_Vect):
			lineAB.Dispose()
def toList(curves):
	curves = curves if hasattr(curves, '__iter__') else [curves]
	if isinstance(curves[0], DS.Curve):
		return [x.ToRevitType() for x in curves]
	elif hasattr(curves[0],  "Curve"):
		return [x.Curve for x in curves]
	elif hasattr(curves[0],  "Location"):
		return [x.Location.Curve for x in curves]
	else: return []
lstCurveA = toList(UnwrapElement(IN[0]))
if lstCurveA:
	outPoint = []
			outPoint.append(pt)
Thanks @c.poupin for your help and contribution… I have no idea why I am getting an error in this line.
@zakim Connect Directly Elements list. No need to add CurveElement.Curve node.
Thanks @Kulkul seems to work directly without the CurveElement.Curve node.
What is strange… the original Python script used to work with the [CurveElement.Curve node]…!
For the purpose of my small project, I am collecting the CurveElement.Curve node lines info, perform some cleanup/List action, then I wish to send the CurveElement.Curve node lines to the Python to create the final polygon. Is this possible?
I updated my previous post to be able to use the CurveElement.Curve node
Thank you very much @c.poupin … it works really well. I have tried different lines/shapes in a small test Revit file. It produced exactly the required Polygon points… Works beautifully … Among other great solutions posted here, I feel this is the suitable one.
Sorry to trouble you with a last question: when I used your Python script inside my overall all project I am working on, the Python does not produce the required list of point to generate the polygon.
Again… Thanks a lot.
Because it’s a bug :upside_down_face:, the script did not work in some cases (according to the order of the input curves)
I fixed it here
Thank you @c.poupin for your great help. I really appreciate everyone’s help :slight_smile:
