I’m trying to get the Group Names of all the Text in my document.
The snippet I have show below works fine as long as the FIRST element found is Grouped, but if the first element is NOT Grouped, the whole thing fails.
Any idea for a work-around? I can’t really sort my list. What I’ve posted is just a snip from a larger program that needs to preserve the original order.
First image shows results if the first element is in a Group
Second image shows the failure when the first element is not in a Group
Doubtless your Python node would be more efficient, but I have figured out a method using only OOTB nodes.
This might not be optimal performance, but it works.
