Hello. I used dynamo to see the openings in the plan in red color, but there was no change in the plan. Thank you for your help in advance.
Hi @Draxl_Andreas are you sure, works fine for me in section and planview
@sovitek ,
overriding works just for projected surface, not when it is in section! (here walls manuel 1.00m)
KR
Andreas
ĂĄrhhh yeah now i know what you mean
then you are right ![]()
@yaseminV2XL5 ,
the trick here is to model a compact Volume to maintain the morpholgy of a “void” set a material to transparent.
ConVoid is doing that in there families…
KR
Andreas
Thanks @Draxl_Andreas and @sovitek
