its empty list cause the directory.content node couldnt find any files within it. Did you download the files from bim360?
no, I did not. I just copy/paste the file path on the pc to BIM360… is it a wrong way?
After several tests, is possible to open, detach and save as multiple file in batch with Revit Batch Processor… It works perfectly, you need the model Guide ID as text
colleagues, I’m sorry if I’m interfering with what you don’t need…
in order not to load links when opening a model, you can use transmissiondata, which allows you to configure the unloading of links without opening models.
it will look something like this:
t_data=TransmissionData.ReadTransmissionData(path)
t_data_links_id = t_data.GetAllExternalFileReferenceIds()
for u in t_data_links_id:
refdata = t_data.GetLastSavedReferenceData(u)
if refdata.ExternalFileReferenceType == ExternalFileReferenceType.RevitLink:
refdata_mas.append(refdata)
link_ref = refdata.GetPath()
linktype_ref = refdata.PathType
t_data.SetDesiredReferenceData(u,link_ref,linktype_ref,False)
t_data.IsTransmitted = True
TransmissionData.WriteTransmissionData(path, t_data)
Hi. Can i have a script for this task?
i will appreciate. Thank you
