Open Central file and transfer type of elements and save and close
hi all am new here
i try to Document Transfer By Type From File To File In The Background and i face this error
( Warning: Document.TransferByType operation failed.
Attempt to modify the model outside of transaction.)
Thanks and best regards
Sarah
may i know the transferbytype node is from which package?
Hi @sarah.9090
Welcome to Dynamo Forum!
Looks like you need to start a transaction before Document.TransferType node
Transaction.Start node and then feed the resulting elements into a Transaction.End node.
Orchid package
Hi @Kulkul
Thanks for your response I will try it , and I will tell you the feedback
Thanks , Sarah
hello @Kulkul sorry if i late
Document Transfer By Type.dyn (39.7 KB)
what i doing wrong ??
I do not believe Orchid supports transactions like this. Best to ask on the Orchid GitHub page: GitHub - erfajo/OrchidForDynamo: This repository contains the content of the Orchid package for Dynamo
Hi @sarah.9090
I modified your script and looks good to me now. Before you run the script make sure you open revit model which you want to transfer and close all other files if you had it open.
DYN File Document Transfer By Type (For Sarah).dyn (26.9 KB)
thanks @jacob.small for this i report the issue to @erfajo
Hi @Kulkul :hugs:
i am so thankful for this amazing effort you do
but i think there is some misunderstand between us
I need to transfer the data from one file to 16 file with the script you show it to me, i will open the 16 file to transfer the data but what i need is to transfer this data from one file into the another 16 file without open the 16 file because it will take so many time to open :sweat:
thanks
sarah
You will have to open the other files because you can’t modify the document (No Valid Transaction) in a document that isn’t open. @Kulkul solution is the best as long and you have the source and target set correctly, or use python to do it.
maybe you can refer to this post for some inspiration?
