you can use CurveLoop.Simplify from Spring packages. Also about importing DWG polylines: Group lines from DWG, PolyCurves from DWG - #13 by Vladimir
Vladimir
4
Related topics
| Getting mesh boundary curves | 1 | 312 | December 13, 2022 | |
| Alpha Shape proplem (Draw outer line around the outside point Cloud at the same plane by ignoring any points that would fall inside.) | 4 | 1578 | December 1, 2021 | |
| Create surface from point | 3 | 711 | February 22, 2023 | |
| How to: Determine corner points of a "face" | 22 | 4797 | August 30, 2020 | |
| Points to surface at revit Dynamo | 5 | 2904 | May 20, 2020 |
