Null to Empty to Variable
I have to ask some frequent tasks that I would like to achieve with OOTB nodes or DesignScript, although I ended up using Python nodes but they do not get to work input as a lists&sublists and not wanting to insert them in a custom node to run with Long lacing mode.
I have seen some people using Imperative Design script or something called Replication guides, not far from the Python codes,
Here what I got so far working with, looking to improve, any suggestion would be appreciated, thanks.
Null to Empty:
inpo = IN[0]
result = []
if isinstance(inpo, (list,)):
	for each in inpo:
		if each == None:
			result.append([])
			result.append(each)
elif inpo == None:
	result = []
	result = inpo
OUT = result
Empty to Variable:
inpo = IN[0]
string = IN[1]
result = []
	for each in inpo:
		if each == []:
			result.append(string)
			result.append(each)
elif inpo == []:
	result = None
	result = inpo
OUT = result
I use this node in all my python scripts to ensure lists are received, even if only one element is provided:
def tolist(input):
    result = input if isinstance(input, list) else [input]
    return result
You can apply similar logic to the first item in a list using try/except statements to force lists of a certain depth to be available, but yes as you said otherwise you will need either imperative design script or custom nodes to make your life easier. I ended up going with custom nodes in the end both for myself (Crumple) and for some of my clients with inhouse packages. It’s just so much easier having level and lacing inputs available rather than making complex Python or imperative statements in most cases.
I agree but for that simple task like a boolean or replacement I think is unnecessary any levels/lacing as I always expect the same output behaviour
Time to learn imperative design script then I guess. I saw you got some help from Vikram on another thread about similar things - check out his post history and there’ll be plenty of examples.
Hi @ruben.romero ,
I’m not sure about what you’re looking for, but is something like this?
def item_tolist (input):
	tolist = input if isinstance(input,list) else [input]
	return tolist
var = item_tolist(IN[0])
result = []
for item in var:
	if item==None:
		result.append([])
		result.append(item)
OUT = result
	return tolist
string = item_tolist(IN[1])
result = []
for item in var:
	if item==[]:
		result.append(item)
OUT = result
I get same identical list before the python script, it does not work for some reason
It didn’t work because you have a list with sub-lists, which means that you have to add another loop to iterate the sub-lists as well. So this would be something like:
	return tolist
string = IN[1]
result = []
first_lp_list = []
for lst in var:
	if lst == []:
		first_lp_list.append(string)
		result.append(first_lp_list)
		sec_lp_list = []
		for item in lst:
			if item==[]:
				sec_lp_list.append(string)
				sec_lp_list.append(item)
		result.append(sec_lp_list)
OUT = result
You can also check @AmolShah solution for a similar case.
Another solution with a python recursive function
I tried to modify the script of @c.poupin to get the results needed, I like that solution easy to edit and runs pretty well. As a resume:
Null to Empty List I get it resolved finally like this:
import sys
def recurseReplace(lst, replace):
	global funcEval
	newlst = lst[:]
	for idx, elem in enumerate(lst):
		if isinstance(elem, list) and len(elem) > 0:
			newlst[idx] = recurseReplace(lst[idx], replace)
			if funcEval(lst[idx]):
				newlst[idx] = replace
				continue
	return newlst
nestedlist = IN[0]
funcEval = lambda x : x is None
NulltoEmpty = recurseReplace(nestedlist, replace = [])
OUT = NulltoEmpty
Also combined double condition of Empty List to String and Nulls to String in a single script with 1 input list and 2 inputs strings, which is something I was looking at the end as well.
import sys
	global funcEval
	newlst = lst[:]
				continue
	return newlst
nestedlist = IN[0]
funcEval = lambda x : x is x == []
EmptytoString = recurseReplace(nestedlist, replace = IN[1])
Nulltostring = recurseReplace(EmptytoString, replace = IN[2])
OUT = Nulltostring
Many thanks for all your support @EdsonMatt @GavinNicholls @Organon @Vikram_Subbaiah , I tested all the solutions provided and learnt something new.
I think it’s time to find your own solution. You already have a lot of good solutions shared by different users. You need to get your hands dirty, instead of adding more requirements for your work, and expect someone else to do it for you.
