Thanks @solamour for the additional feedback. After thinking more about this, it seemed better to wrap all of this up into one node. One key piece was calling the Transaction manually rather than the TransactionManager. No matter how I tried to slice it, it kept telling me I couldn’t edit because no transaction was open.
clr.AddReference("RevitAPI")
sys.path.append(pyt_path)
app = uiapp.Application
paths = IN[0]
if not isinstance(paths, list): paths = [paths]
cats = IN[1]
if not isinstance(cats, list): cats = [cats]
status = []
errorReport = None
for path in paths:
try:
doc = app.OpenDocumentFile(path)
trans = Transaction(doc,'del')
for cat in cats:
collector = FilteredElementCollector(doc)
collector.OfCategory(System.Enum.ToObject(BuiltInCategory, cat.Id))
collector.OfClass(FamilySymbol)
types = collector.ToElements()
trans.Start()
for type in types:
doc.Delete(type.Id)
trans.Commit()
doc.Close(True)
status.append('Closed')
except:
import traceback
if errorReport is None:
OUT = status
OUT = errorReport
Thanks for the help on this one, I needed to learn more about how Dynamo handles items up and down stream of closures and deleted items.
