Multiplication with bracket [ ] on a series on code block?
Hello, I don’t know if it’s a bug or if it comes from the upstream graph
I have to add for the multiplication to be effective
see capture
I attach the file:
16 Decembre forum anglais.dyn (64.0 KB)
I’m on v 2.16.1
Cordially
christian.stan
Can you show us the values being used? Better yet, can you replicated it with everything defined in the code block? This is likely a list structure issue.
Thank you Mr. Nick, well seen, I had made a copy paste on FirstItem (with a level) and I sent a list.
Cordially
christian.stan
