Muliple Links/Inputs to the same Input, possible?
Hey hey,
i want to create a zerotouch library to connect two programs. One node has the purpose to export all data. In order to make it it as convenient as possible i want the export-node to accept n-linked Input. Maybe its easier to understand what i mean if you look the picture below.
Do you know if it is possible?
thanks for your help!
best regards
You could use a List.Join Command. With the four inputs as In and the Output into the Yellow Node
Thanks @Daan. But this is not the solution i am looking for. :slight_smile:
Then i do not understand how you want to put these al into the same node, could you elaborate more?
I want the Input of the yellow Node to accept more input in order to filter them and calculate things. In order to achive that, i only want to know if it is possible the create one Input of a node that accept more than one link. Maybe the API provides such things?
I dont want a workaround, i want to know it there is this solution.
This is not possible. Nodes can only have a singular input connection.
Maybe you could try using a List.Create node and then a GetItemAtIndex with a 0, 1, 2 and 3 and then have the user input one of those four choices.
