Method Python Faster exist?
Is there a method (in Python or Designscript) faster than those applied here.
To create a list of numbers relative to a median with a defined step.
DesignScript:
Val_center;
Step;
Nb_val;
Val_center-Nb_val*Step..
Val_center+Nb_val*Step..
Step;
Python script:
# Charger les bibliothèques DesignScript et Standard Python
import sys
# Les entrées effectuées dans ce noeud sont stockées sous forme de liste dans les variables IN.
Center=IN[0]
Step=IN[1]
Number=int(IN[2])
seq=range(-Number,Number+1)
Result=[]
# Placer votre code au-dessous de cette ligne
for i in seq:
	R=Center+i*Step
	Result.append(R)
# Affectez la sortie à la variable OUT.
OUT = Result
Cordially
christian.stan
Hi @christian.stan
try this
val_center = 25
step = 2.5
number = 5
def d_range(val_center, number, step):
    x, end = val_center - step * number, val_center + step * number
    while x <= end:
        yield x
        x += step
list(d_range(val_center, number, step))
Hello, after reading about the generators I think I have understood the way to do it
Thank you for sharing and providing knowledge.
Cordially
christian.stan
