Hi Guys
i’m trying to get the maximum rectangle inside a Polygon. where springs node minimum area rectangle form a rectangle outside the points of the polygon my need is to create rectangle inside a polygon
Thanks in Advance
Here’s on technique, but i doubt its going to be very straight forward to achieve with visual programming / Dynamo nodes so you might need to consider Python:
