Hi, I’m running into a bit of a beginners error. (I guess) I’m having trouble with the math operators in Dynamo and am looking to understand an unexpected results.
I’m using a list of lengths and want to check if they are larger than a specific value. In this list there multiple items which are equal to the number I’m checking against; I would expect that I would get a False return on those items but somehow I’m getting true.
(I’m using the ‘>’ but I’m getting the same result in code block x>y?true:false;)
This only seems to happen to me on this list of lengths. When recreating the list in a code block I cannot replicate the effect. Also the ‘==’ node seems to work fine, but the ‘<’ & ‘>’ do not.
The value type of both inputs seem to be a double (checking with the Object.Type node). The original input of x has been a value of type length in the unit mm.
Could anyone help me understand why I’m getting these results?
Thank you kindly!
