I’m curious if there is way to create a bunch of filters into Revit at one time based on a custom parameter (Zone ID) that would pull from an excel file?
Did you try searching “Filter” or “FilterRules” or “View Filter”?
Hello Ben,
I think I followed your instructions, however something is astray.
There are two parts to what I’m trying to do, one apply a graphic filter to a view, and then the second part is to control the visibility of that view, i.e. either On or Off. We don’t have to be trapped in the process that I started out, it was my attempt at trying to achieve that outcome, if there is a better way, I’ll gladly accept that, I just could find a node to do it. However you will see I can control multiple…
My end goal is to auto-create view filters for all levels of a project, to hide all rooms and spaces not associated with each view.
Example filter:
[CREATE%20VIEW%20FILTER%20-%203]
I have tried two different methods without success.
Method 1:
[CREATE%20VIEW%20FILTER%20-%201]
Method 2:
[CREATE%20VIEW%20FILTER%20-%202]
On method 2, I was able to get the create view filter to give me a message saying my filter name needed to be unique. I can’t seem to get that result again.
I’ve read vario…
Thanks for the suggestion and here is the end result of what I was looking to achieve with success.
Filter Import.xlsx (8.5 KB)
Batch VIEW FILTER Import.dyn (49.0 KB)
