Hi. Cannot get my head around making a python script that runs the mandelbrot function z=z*z +c
new to python and have tried this script with no luck.
would be so thankful for help!
Can you show what you’re inputting and what’s outputting.
OK… that looks a little chaotic…
What’s going into the python node and what’s coming out.
Can you paste the graph maybe?
Python:
Line 7 : You’ve not defined b, it’s just a totally blank list.
Line 12: C is never used
Line 14 you’re trying to multiply a blank by a blank then by some points
Think will help a lot! Thanks!
Final notes from me:
Be cautious of squaring squares… Think of the parable of the man who invented chess and for his reward asked for 1 grain of rice on the first square, double on the next, double on the next etc…
(the numbers are going to get HUGE)
Also read: https://primer.dynamobim.org/
And look at the sample programs you get with Dynamo.
There’s an example with a coloured ‘worm’ and spiral somewhere in those that you may find useful.
and set the maximum number of iterations
Where does the difference between the 2 versions come from?
Python script:
# Charger les bibliothèques DesignScript et Standard Python
import sys
# Les entrées effectuées dans ce noeud sont stockées sous forme de liste dans les variables IN.
zz=[]
# Placer votre code au-dessous de cette ligne
def z(n, c):
if n == 0:
return 0
return z(n - 1, c) * z(n - 1, c) + c
for i in IN[0]:
zz.append(z(i,IN[1]))
# Affectez la sortie à la variable OUT.
OUT = zz
code block:
n;
z=[];
c;
[Imperative]
z[0]=0;
for (i in 1..(DSCore.List.Count(n)-1))
z[i]=z[i-1]*z[i-1]+c;
return z;
edit:
oops, this is from my incoming (No double)
cordially
christian.stan
<3 Wow:)
Your posts are always on another level!
Love it!
to infinity and beyond with DynamoRevit
import sys
import System
clr.AddReference("System.Core")
clr.ImportExtensions(System.Linq)
clr.AddReference('DynamoRevitDS')
import Dynamo
#reference dynamo core to update node values
clr.AddReference('DynamoCore')
from Dynamo.Graph import UpdateValueParams
#access to the current Dynamo instance and workspace
dynamoRevit = Dynamo.Applications.DynamoRevit()
engine = dynamoRevit.RevitDynamoModel.EngineController
currentWorkspace = dynamoRevit.RevitDynamoModel.CurrentWorkspace
model = dynamoRevit.RevitDynamoModel
clr.AddReference('System.Drawing')
from System.Drawing import Color, Bitmap
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
import colorsys
import math
import time
px, py = -0.7746806106269039, -0.1374168856037867 #Tante Renate
R = 3
max_iteration = 170 #2500
w, h = 400, 400 #1024,1024
mfactor = 0.5
def Mandelbrot2(*args):
get Mandelbrot fractal
x, y, max_iteration, minx, maxx, miny, maxy = args
zx = 0
zy = 0
RX1, RX2, RY1, RY2 = px-R/2.0, px+R/2.0, py-R/2.0, py+R/2.0
cx = (x-minx)/float(maxx-minx)*(RX2-RX1)+RX1
cy = (y-miny)/float(maxy-miny)*(RY2-RY1)+RY1
i=0
while zx**2 + zy**2 <= 4 and i < max_iteration:
temp = zx**2 - zy**2
zy = 2*zx*zy + cy
zx = temp + cx
i += 1
return x, y, i
def gen_Mandelbrot_image(sequence):
bmpOut = Bitmap(w, h)
byteArr = []
ziplst = []
for x in range(w):
for y in range(h):
ziplst.append([x, y, max_iteration, 0, w-1, 0, h-1])
# apply multiprocessing parrlalelisme
threadResult = ziplst.AsParallel()\
.WithDegreeOfParallelism(System.Environment.ProcessorCount)\
.WithExecutionMode(System.Linq.ParallelExecutionMode.ForceParallelism)\
.Select(lambda e : Mandelbrot2(*e))#.ToList()
# color pixels
for x, y, c in threadResult:
v = c**mfactor/float(max_iteration**mfactor)
hv = 0.67-v
if hv<0:
hv+=1
r,g,b = colorsys.hsv_to_rgb(hv,1,1-(v-0.1)**2/0.9**2)
r = min(255,round(r*255))
g = min(255,round(g*255))
b = min(255,round(b*255))
bmpOut.SetPixel(x, y, Color.FromArgb(r, g, b))
return bmpOut
debug = []
nodeK = next((i for i in currentWorkspace.Nodes if i.Name.Equals("K_R")), None)
if nodeK is not None:
# get values
k = int(nodeK.GetValue(0,engine).Data)
R = float(nodeK.GetValue(1,engine).Data)
f = 0.80
RZF = 1/1000000000000
if k < 30 :
mfactor = 0.5 + (1/float(1000000000000))**0.1/float(R**0.1)
print(k,mfactor)
t1 = time.time()
imgM = gen_Mandelbrot_image(k)
print("elasped {}s".format(time.time() - t1))
R *= f
k+=1
params = UpdateValueParams("Code", "{0};\n{1};".format(k, R))
nodeK.UpdateValue(params)
OUT = imgM
work only with IronPython2 and Revit
mandelbrot zoom_v3.dyn (10.2 KB)
Woow
So here is the development of the Mandelbrot fractal. -thought only way to continue after being given such great help was to make a mandelbulb instead.
-Looks promising but takes really long time to calculate.
-Any idea of how to speed up the calculation?
-And what would be a good way to make it into a solid/surface. -A voxel/cuboid approach?
