cnealy
#1
I’m getting an inexplicable error when creating a sheet using the Sheet.ByNameNumberTitleBlockAndView node. See the error message below.
I figure it has to be the lower two inputs, but these are the two nodes I need to use so any potential solutions would be appreciated.
You haven’t satisfied the input to the active view node. Try connecting the active document node into it and it should work as expected.
cnealy
#3
Wow, thank you, I can’t believe I glazed over that. Appreciate the quick response!
