Hi everybody,
I am trying to build a dictionary as a 2D graph which is to show the adjacent points-lines. I have already checked the intersection by a boolean condition (Does.Intersect) and now I need to filter the nested list of lines (curves) according to the boolean value as a sublist of the point they intersect with.
I have tried this with code blocks and nodes but I still cannot see a right result. Here you can see the nested lists and the situation:
list of points:
List of Curves:
and the intersection checking
Important:
I cannot flatten the nested lists as I need the lists as the registration benchmark for later analysis. I cannot also use List.Flatten and List.Chop later as the number of the points and curves are not the same in each sub list in level@3.
